Posted: Thu Feb 21, 2008 4:46 pm
It could be that you have an imbalance in the impeller assembly.
This can be caused by a few different things like one of the vanes has cracked and a little chunk has fallen off, something has come through your air filter (I do hope you are running an air filter) and broken a bit off a vane, or the bearing is cactus.
It's also possible that the oil feed pipe has a partial blockage and at certain revs the oil is not going through properly and the bearing is running dry.
You'll have to pull the turbo off and have a close look inside it.
Don't forget, they spin anywhere up to 100,000 revs, so even a tiny flake coming off one of the impellors can cause a huge vibration.
While the impeller assemblies are checked thoroughly before assembly, a minute, microscopic crack could have been there from new and is only now showing up as a problem.
Let us know how you go.
