Where do i get this material?
stevesports
Postby stevesports » Fri Feb 08, 2008 2:17 pm
hey all. I'm looking at making a custom airbox for a pod filter, now i found a picture of one that looks easier than fabricating one from sheet aluminium. Attached is the picture.
anyone know where i can obtain this material? It seems like a thick sort of matting around 0.5cm thick lined with aluminium. Also anyone know how much would a 50 sq cm sheet would cost?
Steampunk
Postby Steampunk » Fri Feb 08, 2008 2:33 pm
I know this not an answer to your question, but why not look at using this stuff?
heatshield
A fair few ppl here have used it to much success.
PM NMX516
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Feb 08, 2008 3:16 pm
that is a foam with a heat reflective aluminum outer to it. you can get it from clark rubber. but the other stuff from the above post would be easier to work with as you would not need to make a supportive structure. I have just made a fibreglass air box that I plan to cover with it.
stevesports
Postby stevesports » Fri Feb 08, 2008 3:16 pm
yeah essentially i'm after heat shielding material. I was hoping i can get this stuff for like $10-15.
