high impedence.
the link isn't the standard ecu for the avo kit , is it.
if the link can control the 4 injectors then yeah, i would just get bigger injectors and ditch the 5th one.
i am also using an avo kit, (just the hardware, not using their electronics, so i just removed the 5th injector). in my case, i replaced the standard injectors with 460cc ones, and they are controlled by a DFA.
i'm a little confused as to why you're running a link as well as the avo ecu ... i can't figure out how that would work.
injector type
Yes, AVO do sell link ECUs. Having said that there are various Link ECUs. The miatalink is a full replacement,stand-a-lone ECU. I don't believe it is capable of controlling a 5th injector. There was also a Link piggy-back ECU, which maybe capable of controlling the 5th injector. The Miatalink ECU requires high impedance injectors.
This could possibly be it.
http://www.avoturbo.com/avoshop/product ... cts_id=966
J
J
aah, that looks like it. i didn't know link made the 5th injector controller, i'd always seen it referred to as the \"avo subcom\" or similar.
yeah bluey you really need to figure out exactly what ecu you have got, and exactly what it is doing, before you can go any further with any changes to injectors
