coolant bubbling noise
spikey
Postby spikey » Thu Jan 31, 2008 4:26 pm
In the last few days I could hear this coolant gargling sound coming behind the dash,probably the heater core,has anyone had this problem?I'm thinking leaky headgasket,but coolant level has not gone down,the car does feel a bit unresponsive down low compared to it's normal self,idle up to 3000rpms,what can I check to see if it is the headgasket?it is a turbo na6,runs fine apart from that,just want to fix it before it gets worse.
Steampunk
Postby Steampunk » Thu Jan 31, 2008 9:19 pm
white-ish residue in the coolant when you look into the radiator, same with looking at the engine oil cap.
Get someone to to stomp the accelerator, whilst it's parked & in neutral of course, and rev it to 6,000rpm or so, to see the colour of the exhaust smoke.
Once again, whitish smoke could mean head-gasket.
The noise could be your AC though.
Craig
Postby Craig » Thu Jan 31, 2008 9:21 pm
Pop a new thermostat in it, bubbling could be the result of overheating or a possible blockage too.
Steampunk
Postby Steampunk » Thu Jan 31, 2008 9:38 pm
you sure it's not the ol' 'gearbox neutral switch' problem Craig? :mrgreen:
Craig
Postby Craig » Thu Jan 31, 2008 9:43 pm
1red5 wrote:you sure it's not the ol' 'gearbox neutral switch' problem Craig? :mrgreen:
* Removes gearstick and cracks 1red5 over the head with it *
spikey
Postby spikey » Thu Jan 31, 2008 11:18 pm
coolant and oil have no cross contamination,it overheated when my friend was driving,I took it out today and for some reason the tune was very lean so plug in the laptop and put some more fuel in and it seems alright,bubbling noise could be air trapped in the system,will keep an eye or ear on it.
