Adjusting Clutch grip point?
metris
Postby metris » Wed Jan 23, 2008 1:50 pm
How and where do you adjust the clutch grip point in an NB?
Sidepoint: mine isnt slipping as far as i can tell but it seems to be far further out from the floor than it used to be and it all so feels mooshy...
Is this a sign of bad wear?
NA6 turbo cute scary fun machine!! :D
JBT
Postby JBT » Wed Jan 23, 2008 2:16 pm
Could be one or a combination of:
free play adjustment at the pedal;
hydraulic oil in dire need of flushing; and
clutch component (hydraulic or mechanical) wear/failure.
metris
Postby metris » Wed Jan 23, 2008 2:19 pm
Oh goody goody... lucky i just got a better paying job! :lol:
And do you know about adjustment? I used to be able to adjust my little old honda's, though it was a mechanical clutch...
JBT
Postby JBT » Wed Jan 23, 2008 2:39 pm
There is no point adjusting free play unless everything else is checked OK first.
metris
Postby metris » Wed Jan 23, 2008 2:56 pm
Awesome! Thanks for that..!
Will do some measuring and see if everything is as it should be.
:D
wun911
Postby wun911 » Wed Jan 23, 2008 4:17 pm
Sorry nube question...
Are the same specs and measurements for both NA and NB?
every ounce counts
JBT
Postby JBT » Wed Jan 23, 2008 4:33 pm
NA pedal height 175-185mm is the only difference
