help diagnosing problem
JSE
Postby JSE » Tue Jan 22, 2008 6:54 pm
at idle or at constant speed it sounds like a rotary.
like the idle timing is bouncing up and down...sounds exactly like a rotary.
also when next to another car or wall i can hear it like a hissing intake noise up and down in pitch.
any ideas?
idle timing?
throttle body or accell cable?
sparkplugs?
Postby Okibi » Tue Jan 22, 2008 7:32 pm
Checked for leaks in your intake? That will make a hiss and effect idle.
A leak at the exhaust gasket will also make a hiss and change the engine note.
JSE
Postby JSE » Tue Jan 22, 2008 9:25 pm
yeh i checked the intake tubing and filter...its all tight and no holes, gaps...
will check exhaust tomorrow - could be because i have been getting wicked exhaust rattles lately. could just be the heatshielding but as per usual na6
