Blowing Hot & Cold
blackster
Postby blackster » Tue Jan 29, 2008 10:24 pm
I would double check to see if the FM intercooler will fit on our SE without issue. When i looked at intercooler sizes, I noticed that a larger IC (like the FM) would cause fitment issues because of the way our A/C pipping is routed. The MSM air con piping is routed differently to ours.
I would also double check too see if the yanks have experienced a pressure drop with that size intercooler or to see if heating issues have arisen as that IC appears to cover the entire surface of the radiator. Knowing your climate I doubt overheating would be an issue.
Previous
04' MX5 SE.
02' MX5 Classic ed.
