1.8 engine into a 1.6
- JSE
Are there any modifications needed? Or will it fit perfectly straight in and line up with everything including engine mounts and driveshaft?
There's a kit that FM sell that covers most things, BUT .. we've found that the fuel map can still be pretty screwed with the 1.6 ECU.
The best solution is to buy a Wolf ECU that plugs directly into your 1.6 loom to run the 1.8, that way you can tune the 1.8 and make even more power.
Then you just use all the 1.8 bits like the throttle body and ditch the AFM.
Okibi wrote:There's a kit that FM sell that covers most things, BUT .. we've found that the fuel map can still be pretty screwed with the 1.6 ECU.
Does the 1.8 ECU plug straight into a 1.6 loom and will that work withought any drama's?
