Differential ?
Gazbo
Differential ?
Postby Gazbo » Sat Dec 29, 2007 11:57 am
Need people's advice...
My NA6 has suddenly developed a soft \"thump-thump\" noise, coming from the rear, most noticeable when slowly coasting to a stop.
It's wheel speed related, noise is present whether brakes are on or off, clutch engaged or not, and in every gear.
I jacked the rear of the car up and rotated the rear wheels by hand... seems to be a bit of slop and click in the differential.
If I reverse slowly the noise is there, only more of a periodic creaking sound.
Has my differential broken? (not LSD, std open diff)
Is the universal joint stuffed?
Where and how much is a new/2nd hand diff ?
Thanks for any help..
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Alf
Postby Alf » Sat Dec 29, 2007 2:18 pm
Unis?
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
Gazbo
Fixed
Postby Gazbo » Sat Dec 29, 2007 3:28 pm
Problem solved... :oops:
Tip: If you hear groaning and/or creaking noises coming from the rear, check that your wheels nuts haven't come loose.
Postby Okibi » Sat Dec 29, 2007 3:36 pm
Hrmz .. could be a contender for next years awards.
http://www.mx5cartalk.com/viewtopic.php?t=27055&start=0
Craig
Re: Fixed
Postby Craig » Sat Dec 29, 2007 7:31 pm
Gazbo wrote:Problem solved... :oops:
Has Boags been servicing your car again??? :lol: :P :lol:
Hellmun
Postby Hellmun » Sun Dec 30, 2007 1:52 am
I actually find the standard wheel nuts on my car come loose surprisingly easy. I have to tighen the standard ones during trackdays. One time I ran out of fuel and needed to make a midday pit-stop. So the car had no rego plate, no tools etc..all mid track-day and all. Then I get halfway to Goulbourne...and start hearing thud thud thud. Get out, check the wheels...sure enough the nuts are coming loose on rear left. I tighten as hard as I can by hand...go a kilometer, pull over and re-tighten so on... ended up buying a cheap toolset from supercheap, braking the multi-grips and finally getting a 17mm socket to fit on the locking nuts.... have no issue at all with the replacement nuts since though. I mixed up the four on the my rear left into the 3 other wheels after as a test to see if it was the studs or nuts....sure enough each wheel has one nut that comes loose now.
Postby Okibi » Sun Dec 30, 2007 1:55 am
Sounds like you need new wheel studs and/or nuts.
Gazbo
Postby Gazbo » Sun Dec 30, 2007 1:23 pm
Hellmun wrote:I actually find the standard wheel nuts on my car come loose surprisingly easy. I have to tighen the standard ones during trackdays. One time I ran out of fuel and needed to make a midday pit-stop. So the car had no rego plate, no tools etc..all mid track-day and all. Then I get halfway to Goulbourne...and start hearing thud thud thud. Get out, check the wheels...sure enough the nuts are coming loose on rear left. I tighten as hard as I can by hand...go a kilometer, pull over and re-tighten so on... ended up buying a cheap toolset from supercheap, braking the multi-grips and finally getting a 17mm socket to fit on the locking nuts.... have no issue at all with the replacement nuts since though. I mixed up the four on the my rear left into the 3 other wheels after as a test to see if it was the studs or nuts....sure enough each wheel has one nut that comes loose now.
I'd swapped wheels about 6 weeks ago, no problems until a few days ago when I noticed the noises after a drive (rough roads)
Left rear wheel also (co-incidence?). I have the NB8A wheels with chromed dome nuts, one of the nuts that came loose now has the outline of the stud-end showing through in the domed end.
Time for new wheel nuts then? Studs still look OK.
Users browsing this forum: Google [Bot] and 6 guests
