Coolant reroute
Posted: Thu Nov 15, 2007 10:23 pm
Thought I would put up a couple pics of the coolant reroute I just did.
I had a new front neck made up to put the ecu temp sensor in and for a heater outlet. I had one made up in preference to just using a 1.8 front neck to clear the front on the engine as much as possible. The pipe I just had bent up out of alloy which goes down to the 1.6 thermostat housing which is relocated to the back of the head. Alternatively a datsun 1600 thermostat housing can be used on the back of the head.
Thanks to mx5 plus for the help and bits too.
Cheers, Tim
Cheers, Tim
