1. how many wires go into this socket through the right side?
2. what colours go where?
thank you so much, please help straight away!
Juffa wrote:Try this link which includes a wiring diagram (PDF) for the 2000 model. Note it is probably for the USA model, but hopefully will help you.
http://www.madracki.com/miata/wiring.html
On a side note I would suggest that where possible the parts being polished such as the cam cover be removed first. Makes things a lot easier and these kind of problems shouldn't happen.
Good luck with the fix and post some pics when you have completed the polishing.
J
Fatty wrote:seeing as they are both black, they may be earths and it may not matter if you mix them up anyway. at least, i hope so for your sake!
SM wrote:
umm I'm not so sure it doesn't matter,
