Posted: Fri Nov 09, 2007 10:10 am
I fluked it and found a set of genuine Apexi extractors on the net. It's a 4-1 with a \"twisty\" collector.
Butt-dyno definitely says there's more ooomph, and she revs easier and faster to redline.
4-1 systems are supposed to give better top-end at the expense of bottom-end, and most go for 4-2-1 (as I'm sure you know all this anyways), but I couldn't feel any losses with mine.
One important thing to look out for in a quality header are the actual holes/ports in the manifold flange. Make sure the exhaust tubes and ports match.
In other words, cheap systems will just be round tubes welded onto a flange with oval ports, therefore there will be parts of the round tube sticking out into the flow-path, and other parts hidden causing unwanted ebbing of flow.
Am I explaining this properly?
