Page 1 of 2
idle dip - faulty O2 sensor?
Posted: Wed Nov 07, 2007 12:47 pm
by EGG80X
The Idle dip is driving me insane!!!
Changed the spark plugs, cleaned the MAF, throttle body...
and the spark plug leads been upgraded to magnecor 8mm
read on miata.net that it could be the o2 sensor which can cause the idle dip.... Has anyone replace one yet? An which o2 sensor is it?
But I might also check the vaccum lines tonight...... and see how it goes
Posted: Wed Nov 07, 2007 12:49 pm
by Babalouie
Prolly is the idle stepper mechanism.
Not sure if it's the same on NB, but on NZ there is this gizmo bolted to the undeneath of the throttle body (there's a pipe going to it from the plastic crossover intake pipe).
It's a valve that regulates the idle, and it goes on the fritz after a 10yrs or so. Only 100% solution is to replce it.
Posted: Wed Nov 07, 2007 1:08 pm
by EGG80X
Babalouie wrote:Prolly is the idle stepper mechanism.
hmm, is that on your NA8? could be the same for my NB8A
Posted: Wed Nov 07, 2007 1:18 pm
by blackster
Did it idle dip with the
before K&N set up?
Posted: Wed Nov 07, 2007 1:24 pm
by EGG80X
YUP, happened with the no drill mania intake as well
Posted: Wed Nov 07, 2007 4:17 pm
by Alex
so it's just dipping when you come to a stop?
mine's been doing it for a while now, just going down to 500rpm then coming back up again
I'm going to get mania to take a look at mine in a few weeks when I have the next service done
Posted: Wed Nov 07, 2007 4:21 pm
by EGG80X
SM wrote:so it's just dipping when you come to a stop?
yup same thing is happening to mine
Posted: Wed Nov 07, 2007 4:55 pm
by Steampunk
Ok, this is gonna be from left-field but I had this problem on my Ford Festiva after I changed the intake significantly.
Before you all go Pffft! Let me remind you the Festiva actually has a Mazda engine designated B5.
I am obviously not the most knowledgeable, but maybe try to look for a little screw, close by the throttle body, that looks like it doesn't secure anything.
If the BP has the same fundamentals as the B5 then this screw will change the idle stepper-motor, increasing or decreasing the idle RPMs when the throttle butterfly is closed.
My $0.02
Posted: Wed Nov 07, 2007 5:04 pm
by blackster
EGG80X wrote:YUP, happened with the no drill mania intake as well
If its not hapenning with the OEM air box but is happening with the aftermarket CAI, sounds like a MAF sensor issue.
Posted: Wed Nov 07, 2007 7:17 pm
by Alex
well I still have everything stock in my car and I still have this problem
PS. Just did some seartching, so EGG8OX it seems you have had this problem before, seems it's common with NB8A's and 10AE's
some people who have said it's happened to their cars, Blugg, Insurgence, fig, Fra66L, and more
Posted: Wed Nov 07, 2007 8:12 pm
by Richee
This happened to my NA6 and after following these instructions all fixed
http://www.miata.net/garage/KnowYourCar/S7_Idle.htmlnot sure if this applies to NBs though
Richard
Posted: Wed Nov 07, 2007 8:29 pm
by marcusus
Interesting. Might be worth checking that one on mine too. Mine idle dips only when the engine is cold, and that's it. Never does it once it's warmed up.
Posted: Thu Nov 08, 2007 9:04 am
by Garry
Have you set the base idle speed correctly eggbox?
Posted: Sun Nov 11, 2007 8:53 am
by muzza2
Posted: Sun Nov 11, 2007 9:39 am
by EGG80X
Garry wrote:Have you set the base idle speed correctly eggbox?
yes it works fine now thanks!!!!
