$2 mod for SP, 157kw atw
Novice1
Postby Novice1 » Tue Nov 06, 2007 3:12 pm
Keep reading this in readers posts with SP, what is this $2 mod?
Novice1 aka Ron
Boags
Re: $2 mod for SP, 157kw atw
Postby Boags » Tue Nov 06, 2007 3:37 pm
Novice1 wrote:Keep reading this in readers posts with SP, what is this $2 mod?
Novice1 aka Ron
Try here and more info here.
From the second thread:
I wrote:At the moment your turbo takes the boost reading for the actuator from the turbo side of the intercooler piping. This means that after the boost drop of the intercooler the manifold does not see the boost level for which the actuator is set.
By putting in a tee piece in a vac line from the manifold you can get the boost reading after the intercooler - and after the pressure drop. This reading will be 1-2 PSI lower than before the intercooler, so won't open the actuator until later. You are effectively upping the boost by 1-2 PSI, or whatever the pressure loss is across the intercooler. You are still technically running "stock boost" because you have not tampered with the actuator.
I hope that makes sense???
Boags
Go on, buy one! 8)
Novice1
Re $2 mod
Postby Novice1 » Tue Nov 06, 2007 5:24 pm
Thanks Boags:
I, think what you said makes sense:)
Next SP that becomes available in QLD I will swoop like a peregrine falcon.
Novice1 aka Ron
bigdog
King of the kennel
Re: Re $2 mod
Postby bigdog » Tue Nov 06, 2007 6:11 pm
Novice1 wrote:Thanks Boags:
Next SP that becomes available in QLD I will swoop like a turkey buzzard! :shock:
Novice1 aka Ron
:mrgreen: :P I was on my way to look at mine within hours of it appearing here on the forum. Despite having to drive to Canberra to see it :lol: Left a deposit with Tim's good lady and went back by train several days later to pick it up. The top down drive (in the rain) home again only cemented my love for the car. Don't hesitate Ron - there's always someone looking for a bargain.
Novice1
Re: Re $2 mod
Postby Novice1 » Tue Nov 06, 2007 8:25 pm
Novice1 aka Ron
You wont believe this but I actually have your car set as my desktop background .
Also, love the 1st black SP in the SP owners list thread.
CHeers
ROn
MX5-SP
Postby MX5-SP » Tue Nov 06, 2007 9:30 pm
157Kws for 2-bucks! ...are you kidding me? It's a hoax! ...I have it on good authority it only delivers 155Kws. ...if that! ...So what's the benefit?
:roll:
Snow White: Torsen 3.9 LSD, A/Sway Bars, R/Bar Plus Clear Reflectors!
Boags
Postby Boags » Tue Nov 06, 2007 9:48 pm
:lol: @ Darby.
To be fair, not many owners see 157rwKW with the $2 mod. I think the gain is usually much more modest than that, but it does turn 125rwKW into 135rwKW IIRC.
As Darby said; why bother, I'd rather spend the $2 on a cheeseburger. :roll: :lol: :P
Benny
Postby Benny » Wed Nov 07, 2007 10:21 am
Why bother?
Because it's the best low-cost performance mod you can make to an SP!
It really makes a difference that you can feel from the seat of your pants, however, there are a couple of slight downsides.
1. Your fuel consumption will go up, because you're revelling in the extra power and so you keep your foot down more often :D
2. It can make feathering the throttle, while under boost, a bit jerkier than it is standard. :frown:
All you are doing is changing where the car gets its boost reading from.
Instead of pre-intercooler, it will read post intercooler.
Simple.
Boags
Postby Boags » Wed Nov 07, 2007 10:36 am
Benny wrote:Why bother?
Who was ti that said: "I've never met a KW I didn't like..."
Marador
Postby Marador » Wed Nov 07, 2007 10:45 am
Although i havent done the mod yet, i did do a similar mod on my 2002 S15 when i bought it... the piping contained restricters... i went to repco, the guy even fitted the new hose for me... 7 pound went to 9ish... and the car no longer sat besides Integra Type R's :P
Silver SP
Marty
Postby Marty » Wed Nov 07, 2007 11:16 am
I did it and went from this before mod
to this after mod :shock:
you can feel the difference straight away without the dyno. :D :mrgreen:
Silver SP 153.7kw atw for $2
Garry
Postby Garry » Wed Nov 07, 2007 12:10 pm
The amount of power increase will depend on the efficiency (or inefficiency) of your intercooler and pipework. If the guy that built your SP got everything lined up right then the power increase wont be quite as large as one where the bits dont quite fit together properly. So someone like Casey with a perfect SP didn't notice quite the same power increase as a few of the other guys.
If you decide to go ahead with the mod keep an ear out for pinging as you are increasing the boost without changing the fueling. If your car is prone to pinging like my car was then it may not work for you like it didn't work for me.
Novice1
RE SP
Postby Novice1 » Wed Nov 07, 2007 1:03 pm
Just out of interest how does a standard SP and a $2.50 modded SP compare to a WRX in acceleration.
Novice1 aka Ron
bigdog
King of the kennel
Re: Re $2 mod
Postby bigdog » Wed Nov 07, 2007 1:03 pm
Novice1 wrote:You wont believe this but I actually have your car set as my desktop background .
CHeers
ROn
Careful... Marvin will get a swelled head :lol: Caedrus' car is beautiful, as is Garry's and Fredbare's. I'd love to have bought a black one, but I really wouldn't want to wash it twice a day :shock: :roll: :lol:
Marty
Re: RE SP
Postby Marty » Wed Nov 07, 2007 1:24 pm
Novice1 wrote:Just out of interest how does a standard SP and a $2.50 modded SP compare to a WRX in acceleration.
Novice1 aka Ron
Very well. That's all I'm saying :mrgreen:
