Pod Filter tests
- Alex
Pod Filter tests
I have recently purchased a cold air intake for my NB and I'm worried about the open hole at the top of the pod that came with it and I have no previous experience with pod filters so is it normal?
regardless I was doing a bit of research into it and came across this article which tests 10 pod filters for flow rate and filtration
Clicky (it's a pdf file about 1.2MB)
thought some people might be interested especially how the performace and price seem to have no real correlation to the performance
Also here is an article that compares the performance figures of an NB8B with the stock filter then with a pod filter, with dyno readouts
probably best to save these ones then rotate them to read since they are in landscape thanks to the low upload resolution for portrait, each is about 900KB
Page 1
Page 2
Page 3
comments?
Page 1
Page 2
Page 3
comments?
- Matty
- Matty
- Fuzzlet
I cant remember the brand, but the cotten filter found to flow the highest was the one I had on the SE. Gave it a nice induction note (no longer sounded like a pulsar), and made the BOV audible
- Sean
- ducktape69
- 16bit
10% is bs. the best filter system i have ever seen gained about 7% and it costs a fortune.
http://www.pipercross.net/vforce_product.asp
this is a very impressive gain of 13.8hp on a 198hp engine. no way a simple open pod would gain 10%.
- marcusus
Crazy that the 3A tops the bunch in both tests.
Interesting that they made that much gain from simply slapping a pod on the end of the existing piping.
I think I got a 2kw gain at the wheels with my setup I got from suzitech.
It's about a 3% gain, which is tiny compared to what they suggest in that article.
SM: What CAI did you get?
- Captain Spank
- marcusus
- Alex
