WHAT SORT OF POWER FROM N SE??
- Russellb
- RIP Nov 2014
What sot of power and all the SE owner making ??
I think Boyracer made 140 ish KW on his race car
STD road car figares is what i want
Can anyone help me???
With no mod's
With no mod's
My ClubmanRebuild
MX5 SE Rally car is HERE
- Alf
Re: WHAT SORT OF POWER FROM N SE?????????
Russellb wrote:What sot of power and all the SE owner making ????????????
With no mod's
102kW ATW.
Alf
2015 ND MT GT Crystal White Pearl Mica (pic to come)
- Boags
Why all the question marks??????????
Anywhere from 98.8 - 107.5 rwkW IIRC.
- Boyracer
- MX-5 Encyclopedia
- Garry
Marador,
Stock SP's are closer to 120rwkw I would have thought, so either you have an optimistic dyno or your car has had a bit of work done to it. But that's not answering Russellb's question.
- Russellb
- RIP Nov 2014
Thanks for the replys
I had one on the dyno with the SP motorsports intercooler upgrade
and a Autronic SM4. I was haveing detonation problems on 9psi of boost
and only made 122KW
was dissapointed but now that seams preaty good
and only made 122KW
My ClubmanRebuild
- Boyracer
- MX-5 Encyclopedia
- blackster
Russellb wrote:Thanks for the replys
and only made 122KW
20rwkw just from the ECU seems impressive, like boyracer has mentioned most gain is found in the air intake and exhaust, which will make it breath easy and will run 9psi without physically upping boost. The intercooler will basically reduce heatsoak, but i wouldnt expect a large if any gain utilising the OEM airbox and exhaust.
As for the detonation @ 9psi are you reaching duty cycle, how much timming are you running, what is your AFR like?
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Alex
http://www.spmotorsport.com.au/researchdevelopment.htm
that's some info on the SPmotorsport gear testing, read story 2 about halfway down the page
- Russellb
- RIP Nov 2014
I forgot to say tha this SE has the cold air box and a full Exhaust
So this is the reason that i was dissa pointed
All so we did not set the Dynos Barometric pressure and air temp be for
we started. So maybe this contribted to the low figures
Ayway the car will be running his weekend at wakefield park this wil bethe real test
My ClubmanRebuild
- pcmx5
- Vehicle: ND - 2
At Vic Club Dyno days( caulfied Jag- Dyno dynamics) standard SP's made around 113- 116rwkw according to Techno's records.
On the same day/dyno a car that I am pretty sure was an SE made 94-96 rwkw.
Peter
Peter
- Russellb
- RIP Nov 2014
blackster wrote:As for the detonation @ 9psi are you reaching duty cycle, how much timming are you running, what is your AFR like?
only running 12 Deg ignition at 7psi
and a AFR of 11.5 .
with these setting detonation is under control and there is a small safty margin The injector are at 85% duty at 6000 rpm
and the power is flatting out at this point
also does any ony know what the comp ratio is on the SE ?
My ClubmanRebuild
