Posted: Mon Oct 29, 2007 8:58 am
Revs are right for that speed. On long country runs, on the open highway and at constant speed I have gotten over 600km from a tank. This was prior to turbo install. I am now expecting to get better than that as my ECU is tuned to run leaner while not in boost. Have your engine tune looked at. A good tune can offer more protection for your engine, add more power and actually reduce your fuel usage (when not on boost).
ps. The factory ECU cannot be tuned as such, you will need either a add on device such as a Jaycar DFA, a piggy back ECU or a full replacement ECU to control the Air Fuel Ratio.
J
J
