New CIA
Posted: Sun Oct 28, 2007 8:01 pm
by satanoperca
Installed a CIA on my NB over the weekend.
Fabricated up a box the goes over and behind the left head light which seems to be the only place I could use for cold air.
Purchase a unit of this forum including a filter and casing.
Moved the power steering reservior to get it to fit.
Overall, very happy. Finally a sound comes from my NB.
Lost power in the lower end but mid/upper has been freed up.
Un fortunately I suffered panel damage in the process of getting materials for the black housing.
Benjamin[/img]
Re: New CIA
Posted: Sun Oct 28, 2007 8:14 pm
by Juffa
Posted: Tue Oct 30, 2007 12:12 pm
by Curly
Nice install.
I fitted a Mania CAI last week as well - I'm loving the sound of it, but I think it might result in a few speeding fines if I'm not careful.
Posted: Tue Oct 30, 2007 12:34 pm
by Bevan
Nice place to get cold air from Ben!
Can't wait 'til I put my FBI in this weekend.
Posted: Tue Oct 30, 2007 3:01 pm
by jules
Haha, he's awake!
Jules
Posted: Tue Oct 30, 2007 3:40 pm
by AB7
Hi Ben, Looks good
Did you drill a hole behind the headlight?
Also is it hard to move the PS resevoir...some of the tubing is quite solid.
Posted: Tue Oct 30, 2007 4:32 pm
by jules
New radiator time I think.
Jules
CAI
Posted: Tue Oct 30, 2007 7:44 pm
by satanoperca
Hi,
Moving the steering reservoir was not to difficult. You will need about 40cm of hosing and somewhere to drain off the hydraulic oil. I was able to bend the rear hose and utilise one of the exiting bolt holes from the air filter to reattach unit.
There is no need to cut a hole in anywhere. After much search for a suitable hole for the CAI I noticed that there is a hole underneath the head lights. I built a box out of alum and gaffa tape to make sure I had a good seal around the head light taking full advantage of the cold area coming from the front guard. I should be getting very little air from the engine bay.
As stated above the low end is gone but mid to top is great. Already recieved a speeding fine before mod. 70k's in 50 zone while going through a round about. Hopefully I can stay out of trouble, but she does go nicely.
I got to say, the only thing to fault with my NB as a sports car was no sound, that has been fixed 50%. now for the cat back system in the next few months.
Benjamin
Posted: Thu Nov 01, 2007 8:28 pm
by irwin83r
looks great mate.. not intrusive or anything... looks like its meant to be there!
BUT!!
its on the wrong side
jokin nice work
Posted: Thu Nov 01, 2007 8:48 pm
by Craig
Where does this fit under the bonnet???
That's my secret weapon.
Posted: Fri Nov 02, 2007 10:42 am
by satanoperca
Or a DIY large fishtank filter.
Benjamin
Posted: Fri Nov 02, 2007 2:30 pm
by Okibi
Fish looks like chiclids but you wouldn't have any plants left with my fish in there.
Re: That's my secret weapon.
Posted: Fri Nov 02, 2007 6:27 pm
by Craig
satanoperca wrote:That's my secret weapon.
Benjamin
Ahhhh must be a new version of the Polariser is it?
How many extra Kw does it give?
Re CAI
Posted: Fri Nov 02, 2007 6:42 pm
by Novice1
Nice install on the NB.
I, had Loch stewart cold air intake, loch stewart extractors, loch stewart cat back system.
It doesn't sound like an NB anymore, sounds like a racecar and the power increase is very noticeable.
Lightened flywheel makes the NB accelerate so much better.
Cheers Novice1 aka Ron
Posted: Tue Nov 06, 2007 10:40 am
by satanoperca
Change over the spark plugs to irridiums and new leads.
Cleaned the TB and checked all the electrical connections including grounding leads.
The loss in the bottom end is now quite small but the torque increase mid and high end is incredible for such a easy and cheap mod- that be it a lot of my own time fabricating up the induction box to such that cold air in.
When the clutch needs replacing, the fly wheel will be lightened.
Next is to have the injectors flow tested and cleaned.
I love this mod, it has made the car more responsive and with better torque.
Benjamin
