Turbo MAP sensor Vacuum
Juffa
Re: Turbo MAP sensor Vacuum
Postby Juffa » Sat Oct 20, 2007 10:49 pm
silverback2002 wrote:Hi Guys,
Just a quick question installing my new Wolf V500 into my 94 1.8 What would be the best location for the intake air for the MAP sesor on the computer. It looks to be approx 5mm inside diameter. I will not be using the MAF sensor.
I have 2 small vacuums on the inlet manifold one directly at the front behind the butterfy and one at the rear that goes to the fuel reg on the rail. These are very small though.
I need a location for the BOV vacuum too.
should that be at least 3 mm diameter.
What have you guys done in this situation.
Dan.
I am using the one that goes to the fuel regulator for the MAP sensor (4mm garden drip T join) and the front one for the BOV.
J
