Transmission oil change for NC
franjae
Postby franjae » Mon Oct 15, 2007 4:59 pm
Can someone be kind enough to confirm that the location of the drain & fill plugs are the same in the NC compared to the NB8B?
I just noticed the gearbox whine at take off or accelerating from very low speed. Maybe a change of oil will help.
franjae :P
NC sold, but will return one day.......
JBT
Postby JBT » Mon Oct 15, 2007 9:03 pm
It's a pretty standard system as I recall from a look under there when it was up on a hoist. Drain plug at the bottom and fill plug on the side.
franjae
Postby franjae » Mon Oct 15, 2007 11:49 pm
Thanks JBT!
Have you changed your transmission oil yet? Have you noticed if yours has gear oil when taking off?
I thought the layout for this box should be similar to the NB 6 speed. No harm asking!
franjae :)
JBT
Postby JBT » Tue Oct 16, 2007 5:51 am
No franjae, haven't changed the tranny oil - no noises coming from there either.......maybe I've got the Bose up too loud :lol:
Bloo Max is going in for his 10,000km/six month service today. It's four days short of six months and he has run up 9,500 totally enjoyable km now. :D
Charlie Brown
Postby Charlie Brown » Tue Oct 16, 2007 9:20 am
Franjae,
As JBT said the drain plug is on the bottom however there are two plugs on the side and you need to pick the right one, and from memory I can't remember which one. I think it's the one at the rear Driver's side.
I changed my oil out early to synthetic for both gearbox and diff. I found with the synthetic oil the syncros were slower, so if that is going to be a problem for you go with the standard oil.
As for the whine, I have it too, nothing to worry about, it's normal. If the noise bothers you then add some sound proofing to the transmission tunnel.
JBT
Postby JBT » Tue Oct 16, 2007 12:03 pm
I think the fill plug is on the left (pax) side :? ......... hmmmm.
Garry
Postby Garry » Tue Oct 16, 2007 12:08 pm
Thats where it is on the NB 6 speed. Undoing the nut on the right side will result in a gearbox rebuild apparently :shock:
franjae
Postby franjae » Tue Oct 16, 2007 9:39 pm
Thanks guys, yes my previous NB 6 speed, the plugs were on the passenger side so I guess it should be the same with the NC.
Funny, I found the clutch and the gears so much lighter than the NB, yet my wife hates it when she drove it today. Hmmm, looks like this is definitely MY car :lol:
franjae
