1. Custom BP (MSM) engine built by Flyin' Miata
* Short block
o Carrillo forged A-rods
o Weisco forged turbo pistons
+ 9:1 compression
+ 1 mm overbore (increase displacement by 45cc)
o Balanced crankshaft
o ARP studs (head and main)
o New oil pump
o New water pump
* Head
o Multi-angle valve job
o Unshroud valves
o Back cut stock intake valves
o Flyin' Miata adjustable cam gear (for exhaust cam)
o Cutting open valve cover
+ for accessing (and showing off) adjustable cam gear
2. FM2 turbo kit
- Garrett GT2560R water-cooled ball bearing turbo
- 0.60 A/R compressor, 0.64 A/R turbine
- 2.0\" ID (inner diameter) - 2.5\" ID pipes from compressor to intercooler
- 2.5\" ID pipes from intercooler to throttle body
- Ductile iron manifold
- 2.5\" stainless steel downpipe
- All pipes either formed silicone or polished stainless steel
- Cold air intake setup and free flow air filter
