Time to change my gearbox oil
Posted: Fri Oct 05, 2007 11:22 pm
by ma64rk
Hey Guys...
I'm going to replace the oil in the diff and gearbox of my 2001 6-speed.
What should I use in the diff?
What should I use in the gearbox?
What is the best for smoothing out the notchy gearbox??
Any advice is appreciated.
:D
Posted: Sat Oct 06, 2007 12:20 am
by Hellmun
Wrong Forum.
I tried Penrite Sin 75 originally in my 6 speed and found it got notchier and notchier. Got to the point I was worried I was actually losing syncho's so I dropped it out after 3000k's and put in Redline lightweight shockproof. Massive difference but it was $135 for the 3.875 litre bottle. I put royal purple max-gear 75-90W in the diff but that's a Clutch pack diff. On the open diff I just used penrite ten tenth's and that was fine. Came out very clean when I swapped diff centres. Not metal shaving, though again..3000k's on that oil.
Posted: Sat Oct 06, 2007 5:02 pm
by ducktape69
how often should gearbox and diff fluid be changed?
Posted: Sat Oct 06, 2007 6:39 pm
by Hellmun
