Posted: Sun Sep 30, 2007 12:57 pm
by Boags
Hmmm. I don't know about the NB and the MAF, but I know the NA6 will stall if you unplug the AFM.
The NB doesn't have an AFM, are you talking about the MAF or are you a little confused?
Pics would help us help you.
Can anyone clarify that the NB will still run if you unplug the MAF?
Posted: Sun Sep 30, 2007 1:22 pm
by Boags
Roodosutaa wrote:My bad... wasn't aware there was a distinction. Yes technically it's a hotwire mass air flow sensor.
Right, well, I'm no help at all then, as I said; the NA6 it just stalls if you unplug the AFM.
Boags
Posted: Sun Sep 30, 2007 3:52 pm
by Hellmun
Well you can't start an NB if the MAF is dead...I will say that much. Never unplugged it with it running. If there's gunk in the IAC valve it will force it to search for idle a lot.
Posted: Mon Oct 01, 2007 9:11 pm
by Craig
Roodosutaa wrote:Checked out the big forum, took the MAF sensor out for a physical check, no damage, then got out some electronic contact cleaner and sprayed a bit on the electrode/hotwire thingy
More info on this please!
Posted: Mon Oct 01, 2007 10:11 pm
by Craig
Hmmm nice find!
Posted: Tue Oct 02, 2007 10:30 am
by Bevan
NB8B will start without the MAF. I accidentally left it unplugged last time I serviced my car.
Posted: Tue Oct 02, 2007 8:00 pm
by Hellmun
Mine wouldn't start without a MAF... Irwin8er can back me up on that one. I had to steal his for 2 days while I got my ECU upgraded to use a MAP sensor after my MAF died.
