Hole in firewall for CAI .. how to enlarge??? :|
Matty
Postby Matty » Fri Sep 07, 2007 12:02 pm
Bunnings.
you can grind it larger with a suitable cutter on a drill.
You could G-clamp in a wooden plate behind the panel and drill a pilot hole in that for a larger hole saw.
You could use a nibbler.
green_comet
Car Detailing Guru
Postby green_comet » Fri Sep 07, 2007 12:42 pm
I find Dremel drills come in handy with things like that..
or maybe just try what Matty said..
Where are you in Melbourne? I have a few holesaw's
fattima
Postby fattima » Fri Sep 07, 2007 2:21 pm
I'm in Thornbury as well I have some holesaws (don't think I have 3 inch) but I do have a dremel (Ozito imitation dremel) you can borrow if you like. I have used it for cutting panels before, a bit slow but you can be pretty accurate.
Bruce 0407 684 695
Postby bruce » Fri Sep 07, 2007 3:55 pm
Someone post a picture of Nibbler from Futurama!
fattima
Postby fattima » Fri Sep 07, 2007 4:10 pm
Not much planned on the weekend so give me a call anytime. You wouldn't have seen me as I only got the car yesterday!
Postby bruce » Sat Sep 08, 2007 10:39 am
Either Nibbler will give you the same result !
PUR157
Postby PUR157 » Sat Sep 08, 2007 7:11 pm
The car would probably disappear with the small furry Nibbler... what with his apetite et al
:lol:
Oneness of Man and Machine
