types of injectors
blackster
Postby blackster » Fri Sep 07, 2007 1:00 am
If the fuel harness on a 1.8 NA is anything like the 1.8 NB, then only high impedance injectors are PnP, low impedance will require the fuel harness to be spliced to fit the plugs.
Im running 450cc high impedance have no issues with idle, @ 171rwkw there was 15-20% left before duty cycle and thats running the OEM fuel pump. AFR was tuned to 11.8-11.3 across the entire rev range.
Previous
04' MX5 SE.
02' MX5 Classic ed.
blackster
Postby blackster » Fri Sep 07, 2007 11:09 am
Previous
04' MX5 SE.
02' MX5 Classic ed.
