heavy duty clutch
16bit
Vehicle: NB8A - Supercharged
heavy duty clutch
Postby 16bit » Tue Sep 04, 2007 3:20 pm
I have been speaking to Simone about this (thanks) and would like a few more opinions.
I need a new clutch as mine is slipping. I have about 137wkw at the moment and will be increasing boost from 6 to 10psi and getting 805c's at some point too. I am not sure but would think about 170wkw would be possible with this setup and am not too sure on which clutch to get.
I will go with excedy but not sure which one - organic hd, button hd or sprung button hd. Has anyone here got or had the button clutches? If so what are they like to live with. I don't use the car as a daily driver but do live in the city and a fair bit of my driving is done there. any adive would be much appreciated.
tk421
Postby tk421 » Tue Sep 04, 2007 10:12 pm
Hi Mate,
I'm running the FFS kit as you know. Presently at 135-8rwkw but too rich in the mid range so more to come. I'm guessing it will be just under 150 when sorted - pre bigger pulleys at least which like you I plan to fit at a later stage.
I had the exedy HD non button fitted with my install. It was a bit shuddery at first but over time is getting smoother and smoother (at about 1300 k's on it now). I'm told the shudder will go away completely after a few more k's. The big advantage is that its only just perceptibly heavier than stock. Its certainly coping with present power / torque outputs without issue. Since I'm non intercooled I am unlikely to be going to far past 160 odd rwkw mark though. I guess it just depends on how hard you are planning on punishing it and how long you want it to last.
If your'e doing mainly city driving I dunno about a button, I think there's a degree of incompatibility with that sort of use. That said David from Mania suggested that they had recently fitted an SP with a Exedy / Daikin HDB. He mentioned that this cars clutch was a bit shuddery as well however with a few more revs before takeoff it was easy enough to get around it. He did say that the HDB's shudder was unlikely to go away though (though perhaps the owner might chime in with a comment on this :) )
Note that its Mania's practice to install a machined flywheel as part of all clutch replacements so this is not a contributing factor to the above experiences.
Hope this helps
Steve
98 NB8A, Mania CAI, Eibachs and Bilsteins, Whiteline brace, Starcorp's, DBA Slotted and asstd bling, FM butterfly brace. FFS coldside and the whiiiinnne. Now 138rwkw (Glory Run :) ) More with tuning.
http://users.tpg.com.au/usethe4c/Green+Machine.jpg
lowmiata
Postby lowmiata » Wed Sep 05, 2007 10:51 am
I have a exedy HD BB 6 puck clutch with HD preasure plate blah blah blah
if you don't drive it very much its ok
if you drive in the city its a PITA
Its not very forgiving its either engaged or its not
that said once your used to it its awesome!
as comparison Cassie can drive it but its not comfortable!
EVI15 1998 to 2008
16bit
Postby 16bit » Wed Sep 05, 2007 1:39 pm
purchased the standard hd clutch.
Fuzzlet
Postby Fuzzlet » Wed Sep 05, 2007 2:59 pm
I have an ceramic button exedy in the clubman, and as lowmiata said, its a PITA in traffic, but once moving its great. It didnt take much getting used to, and now im used to it, its great. The car shuddered for the first 2000kms or so, but has settled down now
16bit
Postby 16bit » Wed Sep 12, 2007 1:17 pm
got new clutch in and it feels pretty stockish. happy with it!
Fatty
Postby Fatty » Wed Sep 12, 2007 7:47 pm
16bit wrote:got new clutch in and it feels pretty stockish. happy with it!
which one did you get?
16bit
Postby 16bit » Thu Sep 13, 2007 9:02 am
excedy hd organic one - good unit.
