Engine running rough
zoomzoom
Postby zoomzoom » Thu Aug 30, 2007 10:32 pm
My engine seems to be runnig a little rouch, and ideas?
sounds like this
Tim
Boags
Postby Boags » Thu Aug 30, 2007 10:44 pm
New ECU? :D
zoomzoom
Postby zoomzoom » Thu Aug 30, 2007 10:45 pm
not yet :D
ampz
Postby ampz » Thu Aug 30, 2007 10:56 pm
13B PP? :D
Huh?
zoomzoom
Postby zoomzoom » Thu Aug 30, 2007 10:59 pm
Nup, just the 1600
JBT
Postby JBT » Thu Aug 30, 2007 11:17 pm
Cam(s)?
Boags
Postby Boags » Thu Aug 30, 2007 11:19 pm
JBT wrote:Cam(s)?
8)
zoomzoom
Postby zoomzoom » Thu Aug 30, 2007 11:20 pm
Boags'MX5 wrote:
JBT wrote:Cam(s)?
8)
:mrgreen:
JBT
Postby JBT » Thu Aug 30, 2007 11:21 pm
Best come out to track day and show us the difference then :D
zoomzoom
Postby zoomzoom » Thu Aug 30, 2007 11:23 pm
I would if I hadn't spent all my money on my car :D
JBT
Postby JBT » Thu Aug 30, 2007 11:24 pm
silvermiata
Postby silvermiata » Fri Aug 31, 2007 12:02 am
that sounds like a ls1 v8 8) is it a monsta miata :?:
Bevan
Postby Bevan » Fri Aug 31, 2007 12:29 pm
Holy crap! A lumpy MX5! That sounds wicked. :twisted:
Fuzzlet
Postby Fuzzlet » Fri Aug 31, 2007 12:59 pm
Actually I was gonna say it sounded like a panzer tank before it hit puberty.....
Mr Starlet
Re: Engine running rough
Postby Mr Starlet » Fri Aug 31, 2007 4:00 pm
zoomzoom wrote:My engine seems to be runnig a little rouch, and ideas?
sounds like this
Tim
That sounded very much like my other MX5 at idle, but how is it at say over 1k rpm? drives fine but shakes abit at idle? even till now I can't work out what it was, possibly idle speed controller (ISC) faulty...too little/much air and ECU trying to correct that's why you get the oscillation? whatever it is that's causing the ECU to correct hence over correct and so oscillation...O2 sensor?, something in the intake path/loop/circuit? vacuum hoses?...rough timing? Mind boggling :?
Good luck Tim.
Minh
