brakes squeaking
16bit
Vehicle: NB8A - Supercharged
brakes squeaking
Postby 16bit » Tue Aug 21, 2007 12:24 pm
ok people I need new pads at least. car is 98 nb
I am thinking of these Hawk ones
http://www.mx5mania.com.au/product584.htm
and getting some dba slotteds all round maybe
I can't quite afford to get braided lines as well just yet if I get the disks. So I suppose if I can get away with just machining the disks would getting the braided lines be a better investment for the dollars spent over getting the slotted rotors? please keep in mind that I don't do track days (yet) but I do drive spiritedly quite often as I don't use the car to commute to work.
If i get the pads and rotors its going to cost about $1150 fitted
but if i get the pads, machine the rotors and get the braided lines its going to cost about $900
Bevan
Postby Bevan » Tue Aug 21, 2007 12:34 pm
NB8B Full Brake Kit
Full brake set from a 2002 MX5 - discs and calipers - in nearly-new condition. These will fit any NA or NB model MX5 and make a great upgrade to the standard brakes. Be Quick only 1 set in stock.
$1200
And the fit it yourself 8)
16bit
Postby 16bit » Tue Aug 21, 2007 12:41 pm
wont fit 15's will it?
Bevan
Postby Bevan » Tue Aug 21, 2007 12:53 pm
16bit wrote:wont fit 15's will it?
It depends on the rim, but they do fit underneath NB8A rims. :)
Boyracer sometimes has NB8B brake sets for sale, as do MX5 Mania, also Mazford down in Milperra might have some.
mickfred
Postby mickfred » Tue Aug 21, 2007 2:28 pm
Bevan wrote:NB8B Full Brake Kit
$1200
Can I please buy your rear pads and pins/clips?????
YEAH BABY!
meanmx
Postby meanmx » Tue Aug 21, 2007 2:49 pm
$1200
I just bought a set of these from MX5plus in Brissie. Can't wait to get them. The front rotor is 270mm diameter versus 235mm on mine and the back is 275mm versus 230mm on mine. Should come in useful for those Mt Dandenong runs and if I get out on the track.Only had 17,000k's on them as well.
Ben
2014 VW Mk7 Golf R
Bevan
Postby Bevan » Tue Aug 21, 2007 3:06 pm
Oh, and you can sell your NB8A brakes to a person with an NA. It's an upgrade for them. Should get at least $500 back. 8)
16bit
Postby 16bit » Tue Aug 21, 2007 3:07 pm
yeah they have another set coming in that I am considering.
16bit
Postby 16bit » Tue Aug 21, 2007 3:41 pm
just one more thing - these bolt straight up to the hubs right?
Bevan
Postby Bevan » Tue Aug 21, 2007 4:06 pm
http://www.aus-cartalk.com/viewtopic.php?t=26872 - Quickly!
And yep, straight bolt-on. :)
