Is it possible to adjust the mixture at idle?
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Tue Aug 14, 2007 11:21 am
Is it possible to adjust the fuel mix at idle? -
I don't think I'm talking about the idle adjustment screw, which I understand is throttle related -
I'm talking about adjusting the fuel mix - mine seems to be running rich after the new motor install.....
Any assistance available?
Fatty
Postby Fatty » Tue Aug 14, 2007 11:25 am
you have a piggyback for fueling don't you? wouldn't that be adjustable ? :?
Matty
Postby Matty » Tue Aug 14, 2007 11:34 am
yes and no...
You can tweak the air flow meter (at least you can on a 1.6 with a hidden screw) to alter the meter output signal at idle, hence the fuel mapping will change.
However, with the O2 sensor warmed up (ie, engine not cold), the ECU will operate closed loop and bring the mixture back to stoich.
Uncle Arthur
Postby Uncle Arthur » Tue Aug 14, 2007 11:38 am
Matty wrote:yes and no...
That will be the hidden screw under the raised metal cap????
The issue is that the car idles ok initially (when cold albeit with raised revs) and then slowly startts to fail - it did it this morning and I could smell the fuel, so she's rich. I also had to wait a little bit for it to start again.....
There's some info on the web here and there about the idle control valve - I'm presuming that's the 'attachment' on the engine side of the plenum on the 1.6?
I'm thinking with it having been off the car for a while it may be sticking - anyone here got any experience with checking/fixing this part too?
zoomzoom
Postby zoomzoom » Tue Aug 14, 2007 12:02 pm
Yes it is under a little metal plug. To remove this just drill a small hole through it then screw in a self tapper and use this to pull the plug out with.
I'll get a pic tonight if it helps(and I remember :D )
Tim
