Oil for a Torsen
Adam_NAclubman
Oil for a Torsen
Postby Adam_NAclubman » Tue Aug 07, 2007 3:32 pm
What do I use? I'm fairly sure I had to use a different oil to the stuff normally used in Viscous LSD's for the mechanical diff in my DR30, so I'm unsure of what type the Torsen needs?
Juffa
Postby Juffa » Tue Aug 07, 2007 4:03 pm
I'm using a Castrol oil in my Torsen diff. The bottle is labeled as being for Limited Slip Diffs. Took around 1 litre from memory.
I'm pretty sure it was this one.
Castrol LSX 90
Mineral gear oil recommended for cars and commercial vehicle axles operating under higher frictional loads, especially limited slip differentials and those experiencing clutch chatter. Meets Mack GO-J quality thermal stability requirement. SAE 90, API GL5.
J
JBT
Postby JBT » Tue Aug 07, 2007 10:00 pm
The 1.8 Torsen doesn't need any special LSD oil - it's all helical gears and no friction plates/cones.
Craig
Postby Craig » Tue Aug 07, 2007 10:18 pm
JBT wrote:The 1.8 Torsen doesn't need any special LSD oil - it's all helical gears and no friction plates/cones.
x2
Adam_NAclubman
Postby Adam_NAclubman » Wed Aug 08, 2007 2:06 am
So I just use normal diff oil or what?
JBT
Postby JBT » Wed Aug 08, 2007 1:59 pm
Yes, normal (good quality of course) diff oil.
Adam_NAclubman
Postby Adam_NAclubman » Wed Aug 08, 2007 6:22 pm
I bought a litre of Motul 75-90
atomic
Postby atomic » Thu Aug 09, 2007 1:57 am
how about redline? i keep hearing about that...
JBT
Postby JBT » Thu Aug 09, 2007 7:48 am
This stuff is fine without sending you broke:
CASTROL EPX 80W/90 - Multipurpose gearbox, steering gear and differential oil for passenger cars, light trucks, farm tractors and earthmoving equipment. SAE 80W/90, API GL5.
Lucky_Luke
Postby Lucky_Luke » Thu Aug 09, 2007 9:08 pm
I'm using Redline - Shockproof, its about $42 from autobarn.
L.
