Radiator Repair Stuff
adamjp
Postby adamjp » Sun Aug 05, 2007 6:20 pm
Does anybody know of a radiator repair putty/gel/silicone like substance that I can use to try and seal the cracks in the plastic end tanks?
You may recall that I initiated the group buy back in March because of the cracks in my radiator. I am refilling the car daily, cannot drive more than 150km before more water is required and cannot dare leave it out overnight (not that I would normally) as there is no anti-freeze in there. Not a big issue in Sydney or Brisbane, but south of Canberra, it IS an issue.
Since Mania are being their usual elusive and uncommunicative selves I have no idea when the aluminium radiator I have actually paid for will be delivered. Three weeks ago there was a vague promise that they were 'in customs', but that is clearly crap! :evil: Offers of a temporary stock replacement have not materialised into anything and the whole affair just reinforces my thoughts on what are good and bad business practices.
Adam
timk
Postby timk » Sun Aug 05, 2007 7:25 pm
I used one of those radiator repair kits from Super Cheap Auto. It is a two part thing you mix up and paint on over a sheet of fibreglass. Seems to do the trick for now, my PWR 40mm has been ordered though! 8)
JBT
Postby JBT » Sun Aug 05, 2007 8:31 pm
Take it to a radiator place and get a new top tank fitted. You can always sell that radiator when the new one (eventually) arrives.
adamjp
Postby adamjp » Sun Aug 05, 2007 11:23 pm
Thought about that, the bottom is also old, as it the core. IMHO it is not worth the work.
I will go and lurk at an auto parts place.
Adam
JBT
Postby JBT » Mon Aug 06, 2007 2:16 pm
It's the top tanks that take all the punishment usually. They will normally clean out the core before fitting a new top tank. You'd be surprised how good the core may be................unless no inhibitor has been used for a long period, then all bets are off.
Postby Okibi » Mon Aug 06, 2007 6:57 pm
Is there someone in your local MX-5 club who can lend you a radiator until yours arrives?
I'm sure someone's gone aftermarket and has a spare OEM one laying around.
Fuzzlet
Postby Fuzzlet » Mon Aug 06, 2007 9:43 pm
Dont give up on mania - I was in there and they were rather busy. How long ago did you order your radiator? It took 6 weeks for PWR to deliver my radiator...even then it was wrong, so was another 6 weeks for the replacement to arrive
blackster
Postby blackster » Mon Aug 06, 2007 10:18 pm
http://www.youngsmp.com.au/superseal.htm
Can be purchsed online $20 or from one of there few resellers in NSW, ie artarmon
CRC has a similar product
http://www.crcind.com.au/catalogue.nsf/ ... enDocument
Previous
04' MX5 SE.
02' MX5 Classic ed.
