Any Benifits with POD style oil breathers?
Ajay
Postby Ajay » Thu Jul 19, 2007 3:52 pm
Hey Guys
What are the Pros/Cons of the pod style oil breathers?.. are they purely cosmetic or do they serve a purpose?..
Ajay
Benny
Postby Benny » Thu Jul 19, 2007 5:15 pm
I thought these were illegal, as every car has to have PCV (positive crankcase ventilation) which means the engine \"breathes\" into the sump.
Is this right, or am I thinking about something else?
NMX516
Postby NMX516 » Thu Jul 19, 2007 6:30 pm
The 'advantage' is that no oil vapours enter the intake, hence providing cleaner air for the engine to use and so can perhaps be tuned a bit more reliably... only a real advantage on highly strung cars, which are tuned to the nth degree to get every last little bit of power out of the engine.
Yes, they are illegal if setup just as a filter off the rocker cover, but there are some catch tanks/catch cans, which can be setup legally.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Jul 19, 2007 8:12 pm
as above the oil vapour lowers the effective 'ron' rating going into the engine. if you are tuned to the max on the highest ron fuel then these vapours could be the difference between serious hp or serious engine failure. I have one for asthetics only. It is much more closed then that though.
as you can see hanging off the side in black.
Ajay
Postby Ajay » Thu Jul 19, 2007 10:04 pm
so putting this on a stock NA6 is purely cosmetic.. and it wont damage my engine or anything would it?... thanks for all the replies guys..
Ajay
Postby Ajay » Thu Jul 19, 2007 10:06 pm
and also.. do i need to PLUG the hole on my Enlarged intake piping (where the old tube oil breather goes?..
thanks
Boags
Postby Boags » Thu Jul 19, 2007 10:41 pm
mx5_boy wrote:and also.. do i need to PLUG the hole on my Enlarged intake piping (where the old tube oil breather goes?..
thanks
Yes, absolutely.
