curious?
Posted: Sat Jul 14, 2007 6:51 pm
by RG.net
hey guys, i was just thinking for a minute and i plan to get myself a mania cai down the track (or a diy cai) but when i get off my P's the mx is going turbo, so i will be left with a hole in the firewall
will this effect anytihng?
also i was curious if it was possible to atatch the turbo fan to the hole via a hose or something, if this was done do you think that it would help spool the turbo quicker?
Posted: Sat Jul 14, 2007 7:47 pm
by Bevan
Sorry if i'm wrong, but isn't your car an auto?
Posted: Sat Jul 14, 2007 9:29 pm
by adamjp
Yes you can fit the turbo inlet up to the hole in the firewall.
If you are looking for bits consider this guy near Wollongong.
http://www.jntperformance.com.au
I built my DIY CAI from parts supplied by him. Very good service and top quality product. I will be going back when I need some more bits.
Posted: Sun Jul 15, 2007 5:02 pm
by RG.net
bevan yes it is an auto but i always said i was going to change it!
Posted: Mon Jul 16, 2007 12:30 pm
by Alex
if your still looking at changing I noticed this thread before
http://www.aus-cartalk.com/viewtopic.php?t=26215
Also talk to Fuzzlet about the maina cold air intake and having a turbo because I'm sure he uses both at the same time, then again I think boags had one before he went turbo and has just left the hole in the firewall
edit:
confirmed that fuzzlet did use the mania cold air intake with his turbo
Fuzzlet wrote:Plus the advantage of using an SP manifold and dump pipe meant the turbo could be mounted low enough to still use the mania CAI.
Posted: Mon Jul 16, 2007 12:38 pm
by Fatty
yes you can use the hole, it just means there might be a bit more work / stuffing around with your pipework. and yeah from memory fuzzlet did it that way. here is another example -
