Hello.
I am tryig to remove the lock nut from the center of the wheel hub (e.g. the one which you have to stake with a chisel)
does this nut undo clockwise or counterclockwise?
e.g. http://www.clubprotege.com/wil/howto/rightaxle/unstakenut.jpg
thanks!
URGENT!! - wheel lock nut qtn (center)
- adamjp
I have done front passenger and rear drivers.
From memory both undid in the normal direction (anti-clockwise).
But both were very tight, requiring a very long breaker bar to undo correctly. The rear one took my snap-on bar (2ft long) and my entire weight (100kg) to undo. I split my finger open when the socket slipped torquing the damn rear one up.
Use a 6point socket for extra safety.
Adam
