running too rich?
atomic
running too rich?
Postby atomic » Thu Jul 12, 2007 1:11 am
How can you tell and how easy is it to adjust?
I'm just suspecting cos there's a really strong petrol smell, esp when the engine's just started and the economy seems poorer than usual.
Thx
PUR157
Postby PUR157 » Thu Jul 12, 2007 1:33 am
One of the more obvious signs is the car spewing black smoke under hard acceleration
If your cars bum is covered in black soot very soon after a wash this is also a sign...
Sorry but this young 'un can't help you much more than that... :oops:
Oneness of Man and Machine
Sean
Re: running too rich?
Postby Sean » Thu Jul 12, 2007 2:43 am
atomic wrote:How can you tell and how easy is it to adjust?
Thx
It's not easily or readily adjustable. Although if it is running rich something will be casing it to be that way, get that fixed and your problem is solved!
StanTheMan
Postby StanTheMan » Thu Jul 12, 2007 8:57 am
but one way to do it....is Get your ECU Polarised. :lol:
or muck around with the spring in your AFM if your car is a NA6.....not possible on anything later
But both should be aproached with care & common sense. And like Sean suggested.....fix everything else first before you start mucking around with those bits.
Postby bruce » Thu Jul 12, 2007 10:51 am
Sure you're not having a bit of petrol leak into the boot problem (to cause the fumes) ?
JBT
Postby JBT » Thu Jul 12, 2007 11:24 am
Sounds more like a leak than rich running.
atomic
Postby atomic » Thu Jul 12, 2007 1:29 pm
What are some of the things I should be \"fixing\" first?
(or checking to see if it needs fixing)
It's definitely not a fuel leakage.
Thx
StanTheMan
Postby StanTheMan » Thu Jul 12, 2007 1:39 pm
lets start with the type of Car you have
StanTheMan
Postby StanTheMan » Thu Jul 12, 2007 1:41 pm
what sort of economy are you getting
what type of driving are you doing.
eg short trip, long trips, city driving......so on.
first thing I get is when i'm reversing out.....is a whif of petrol. But its real cold atm & my trips are few & very short. Fuel econ is crap......but thats expected
Boags
Postby Boags » Thu Jul 12, 2007 5:57 pm
Sounds like a bung O2 sensor to me. :D
atomic
Postby atomic » Thu Jul 12, 2007 6:23 pm
StanTheMan wrote:lets start with the type of Car you have
Actually you've seen my car - yellow NA6, black rims....
StanTheMan wrote:what sort of economy are you getting
just regular driving, 20+ min trips around syd suburbs, usually not too much traffic
Maybe it's normal then? No black marks around the exhaust/rear bumper but I definitely get a strong whiff of petrol.
I've just been noticing that I'm getting close to 10L/100km whereas before I used to get around 8L/100km...
Postby manga_blue » Thu Jul 12, 2007 9:31 pm
Sounds very O2 sensor-ish to me. If it's 4-wire now just replace it, if it's a single wire then upgrade to 4-wire and it'll be much better from cold.
http://www.aus-cartalk.com/viewtopic.php?t=25609
http://mymiata.paladinmicro.com/Miata4-WireO2.htm
http://www.aus-cartalk.com/viewtopic.php?t=25688
... and maybe another 10 or 20 O2 sensor threads I have not seen as well.
JBT
Postby JBT » Thu Jul 12, 2007 11:11 pm
atomic wrote:......there's a really strong petrol smell, esp when the engine's just started and the economy seems poorer than usual.
You don't necessarily smell fuel when running rich. A "really strong petrol smell" is indicative of a leak.
What does the exhaust look like? Is it blowing plumes of black smoke?
atomic
Postby atomic » Thu Jul 12, 2007 11:22 pm
not really.
Only when I really give it a decent caning... and even then, it's just a few times initially, then it clears up. I'm thinking that's more carbon build up?
I guess maybe it's O2 related then... ?
Definitely no leak in petrol
SPy vs. SPy
Postby SPy vs. SPy » Fri Jul 13, 2007 12:45 am
check for an exhaust leak around the headers/exhaust before it gets to the O2 sensor, won't take much of a leak to cause chaos with fuel consumption.
