anymore on an mps model?
irwin83r wrote:how many cc's is the NC motor and how many rwkw do they make??
Bevan wrote:Yeah, but he's still got the advantage. Andrew only needs to shave his head to lose a few kilograms...Charlie Brown wrote:Looks like I'm going on a diet.
Charlie Brown wrote:Hey Andrew,
Just realised that your NB has a better power to weight ratio than the NC.![]()
Andrews NB 83.8kW / 1000kg = 0.0838
...............NC 91.6kW / 1106kg = 0.0828
irwin83r wrote:if you have a worse power to wieght why are you leaving me so far behind on the straights??
Charlie Brown wrote:irwin83r wrote:if you have a worse power to wieght why are you leaving me so far behind on the straights??
When I followed you at Wakefield in the damp, there was no difference down the straight.
In the dry the difference is that I'm braking later and getting out of the corners quicker and therefore carrying more speed down the straight.
Ask Turbo Girl about the NC closing under brakes on the silver Rooke beast.
Charlie Brown wrote:...In the dry the difference is that I'm braking later and getting out of the corners quicker and therefore carrying more speed down the straight....
