2 problems with engine?
Posted: Tue Jul 03, 2007 11:56 pm
Okay heres the story... (Na6 with B6 engine turbo conversion)
Drove to my mates place, no problem and i turn into the driveway it starts sounded like a vw boxxer engine! then the engine died. tried starting it again and it was the same. and the headlights wouldnt go retract back down.
Got out and left it for abit. then got back in the boot to make sure the negative and positive terminals wasnt loose. then it started and ran fine.
Few minutes down the road i open it up, it started hesitating 4-5000rpm?
Then it dies again. Pull over and the car cranks but no starting. Left it for bit again and tried again, engine on start up hesitating 3-4cyl? And now loud noise of metal problem inside? But coming from the top end of the motor. Battery has 12vdc. Couldnt check if it was charging the battery though cause it woulndt run long enough keept wanting to stall.
I think the posibilitys are:
1) altinator died
2) Battery Died
3) Coil pack (do have spare but havnt tried yet)
4) Leads (only replaced them 1month ago
5) Fouled spark plugs?
6) engine wise: hydralic lifter/s failed? causing loud noises intop end.
7) valve burnt?
yet to do a compression check. has good oil pressure on cranking.
Any thoughts or simlar experiances? espically the Hydro Lifters failing!?
Thanks
1) altinator died
2) Battery Died
7) valve burnt?
Thanks
