Resetting ECU
Posted: Mon Jun 25, 2007 3:48 pm
by deez
How do you go about resetting the ECU on an NA6? What are the advantages/disadvantages of performing an ECU reset?
Cheers guys.
Posted: Mon Jun 25, 2007 4:39 pm
by Fatty
only reason to re-set ecu as far as i know, is to clear any fault codes. simplest way that i know of is to disconnect the battery and step on the brake pedal for about 10 seconds.
Posted: Mon Jun 25, 2007 5:01 pm
by StanTheMan
What happened to connecting GND & TEN in the diagnostic box?
Posted: Mon Jun 25, 2007 5:38 pm
by ampz
Nothing... :mrgreen:
You use GND + TEN to set your timing and base idle speed.
You can permanently reset it by dropping it in water though :shock: :P
Posted: Mon Jun 25, 2007 5:42 pm
by bruce
Ya reckon loading Vista will make my car quicker?
Posted: Mon Jun 25, 2007 6:04 pm
by ampz
:lol:
Posted: Mon Jun 25, 2007 10:21 pm
by Bevan
Fatty wrote:only reason to re-set ecu as far as i know, is to clear any fault codes. simplest way that i know of is to disconnect the battery and step on the brake pedal for about 10 seconds.
I haven't heard of the brake pedal thing before, as there's no power going to anything, so it could flick any switch or anything. But yes, disconnecting the battery is the only way to reset it. Just disconnect it for a few minutes. :)
Posted: Tue Jun 26, 2007 10:49 am
by GP
Sorry to go off topic.
Do you connect these 2 terminals together and then turn the screw in the throttle body to set the idle?
I've been scewing this thing in and out without anything happening.
Posted: Tue Jun 26, 2007 11:48 am
by Richee
Try this - cured my idle drop issues
http://www.miata.net/garage/KnowYourCar/S7_Idle.html
Posted: Tue Jun 26, 2007 12:07 pm
by Benny
bruce wrote:Ya reckon loading Vista will make my car quicker?
Maybe, but as you don't have a Start button in your car, you won't get it going and if you do, you won't be able to stop it.
Anyway, where would you put the USB plug?
Posted: Sun Jul 01, 2007 1:17 pm
by Sean
Damn MAC Converts :lol:
