How do you go about resetting the ECU on an NA6? What are the advantages/disadvantages of performing an ECU reset?
Cheers guys.
Resetting ECU
- deez
Resetting ECU
89 Eunos Roadster
- StanTheMan
- ampz
- Vehicle: NA6 - Turbo
- bruce
- Vehicle: NA8 - Turbo
- ampz
- Bevan
I haven't heard of the brake pedal thing before, as there's no power going to anything, so it could flick any switch or anything. But yes, disconnecting the battery is the only way to reset it. Just disconnect it for a few minutes.Fatty wrote:only reason to re-set ecu as far as i know, is to clear any fault codes. simplest way that i know of is to disconnect the battery and step on the brake pedal for about 10 seconds.
- Benny
bruce wrote:Ya reckon loading Vista will make my car quicker?
Maybe, but as you don't have a Start button in your car, you won't get it going and if you do, you won't be able to stop it.
Anyway, where would you put the USB plug?
- Sean
Benny wrote:bruce wrote:Ya reckon loading Vista will make my car quicker?
Damn MAC Converts
