Informous High Idle
qik_260z
Informous High Idle
Postby qik_260z » Wed May 23, 2007 10:38 am
Hi guys i have had a look at a few other posts on this topic and also tried the suggested ECU reset thing but my car continues to idle at 1200rpm with the idel control screw all the way in so its really at about 1500rpm when the screw is in a normal position.
Any advice on what to try next would be much appreciated.
Clint
GP
Postby GP » Wed May 23, 2007 10:46 am
Mines the opposite, Idles at 600 rpm and that screw makes no difference at all. I despise EFI :evil:
Graham
Garry
Postby Garry » Wed May 23, 2007 11:11 am
Check that the throttle plate is resting on it's stop and look for vacuum leaks around the intake. Your idle speed controller may be stuck open or if you have a NA6 the cold idle valve thingo on top of the inlet manifold may be stuck.
There's a few things to get you going.
Bevan
Postby Bevan » Wed May 23, 2007 11:12 am
Take the intake arm off
Spray cleaner around butterfly
Wipe with rag that has cleaner on it (actually open the butterfly to do this) Wipe with dry rag
Finished. :)
qik_260z
Postby qik_260z » Wed May 23, 2007 11:13 am
yeah sorry forgot to mention it is an NA6. Occasionally (very) when i turn the car back on and its warm it sit a bit lower but not for very long.
jules
Guitar Hero
Postby jules » Sun May 27, 2007 9:08 pm
Do a search. I fixed this problem with a new ISC. Mine got stuck and needed replacing. I did a writeup of what needed fixing.
Search for weird high idle
Jules
