Removing NB8B exhaust
Posted: Wed May 16, 2007 10:44 pm
Well wow, NB8B's have a LOT of under-body bracing and it's done tight from the factory.... In the last 2 days I've claimed the lives of a 1/2\" drive, a 1/4\" drive. 14mm, 17mm and 19mm spanners. Bent a sid-chrome ratchet handle and discovered that only 2 out of about 7 of the 14mm sockets I have...fit these odd standard nuts on the stock exhaust manifold and the flange directly after the manifold before the EGO sensor....
By pure stubbornness I have managed to get everything off...but the EGR fitting on the end of the standard manifold....
So now that I'm relatively finished...is there any simple solution to breaking bolts/nuts put on from factory with a rattle-gun overly tight?
Also do all Mx5's have water reservoir's the size of Texas? I plan on moving it so it's not melted by the racing beat headers but I really don't think it's going to clear the bonnet if I move the reservoir down to where the standard air filter box was.... Or am I underestimating how sturdy the standard plastic is?
