fuel consumption on the nb? & gearbox ratios?
- sprx3
hey guys,
I cant seam to get any better then around 10L:100km with my nb, & if i drive it hard its even worse, i would have thought i should be getting 8ish from normal driving... is this nornal or should i be doing some checks?
also ive noticed the gear ratios arnt the best for hwy cruising & wanted to know what the models came out with if they are different & what the 6 speeds have in them.
cheers
cheers
- StanTheMan
depends what kind of mods your car has.
excaust , CAI & so on.
My fuel consumption went up after the instalation of the CAI......because i love the sound of it. & therefore always on the gas.
Also depends how long your trip are. Loys of short trips....kiollls the fuel consumption.
Gotta agree with ya there Sprx, sure my old Calibra used to get equal consumption when driving for economy. Why? Is there something inherently ineficient in the MX? Is the EFI a bit generous? Poor aero? Compression ratio? Hasn't got a lot of weight to pull along, I don't get it.
Cheers, Dave, 1990 NA6
Via est vita.
Via est vita.
- Alex
with my NB normally I let it warm up a bit (until the needle get's to the normal halfway point) before taking it above 4k rpm so i'm normally a slowish driver for the first 4 mins of driving before I take it up to redline
and my fuel consumption seems to be around the 10L/100km mark constantly except when i take it on long trips then I can get as low as 7.5L/100km
check your tyre pressure and air filter
also what fuel do you use?
- sprx3
SM wrote:with my NB normally I let it warm up a bit (until the needle get's to the normal halfway point) before taking it above 4k rpm so i'm normally a slowish driver for the first 4 mins of driving before I take it up to redlineand my fuel consumption seems to be around the 10L/100km mark constantly except when i take it on long trips then I can get as low as 7.5L/100km
hehehe thats funny, my easy driving is 1/4 accel & 3k ish changes
tyre pressure did make about 20km a tank difference going up form 30 to 35 psi, it has a pod which im going to look at replacing with the stock box & a k&n filter & im using std fuel, ultimate didnt give me a difference
- timk
sprx3 wrote:SM wrote:with my NB normally I let it warm up a bit (until the needle get's to the normal halfway point) before taking it above 4k rpm so i'm normally a slowish driver for the first 4 mins of driving before I take it up to redlineand my fuel consumption seems to be around the 10L/100km mark constantly except when i take it on long trips then I can get as low as 7.5L/100km
hehehe thats funny, my easy driving is 1/4 accel & 3k ish changes![]()
Did you keep the air temp sensor in about the right spot when changing to the pod filter (ie reading ambient air temperature)? If its hiding down near the exhaust manifold reading higher then normal temps the ECU might be pumping in extra fuel to "save the motor".
My SP almost never returns figures worse then 10l/100km - it is usually around 8-9l/100km in normal driving (not necessarily sparing the horses though) and even better on the freeway.
- Boags
With a mixture of highway, town and spirited hills driving I return 10L/100km at the worst. My car is running overly rich in boost at the moment too... I would regularly get 450Ks for 35L of fuel with the CAI before the turbo went in... I have a 1.6L though.
Boags
Boags
- Craig
- Vehicle: Non MX-5
Fatty wrote:maybe you need a new o2 sensor or something?
Gearbox neutral switch can be the culprit too, as apparently it thinks you're just revving it in neutral and hence doesn't deply the O2 sensor...or so I hear!
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
- Boags
Great call! I'd be checking that first...
Boags
- sprx3
Craig wrote:Fatty wrote:maybe you need a new o2 sensor or something?
ahhh now thats the kind of info im after.....
you got any more of that & where do i find it (yeh im guessing its on the box
also guys im really after the ratios of the 5 & 6 speed boxes as im looking at going to a 6 speed in it if it has a better overdrive then the 5 speed boxes
- Craig
- Vehicle: Non MX-5
From what I've heard the wirings cable tied under the car, and when a clutch is replaced the mechanics can just leave the cables dangling around, and over time the wires stress internally and break. I'm pretty sure mine needs one or the O2 sensors knackered as the fuel consumption is much worse than the NA's I used to own.
In earlier ECU cars the neutral switch (in parallel with the clutch switch) is only used to detect a stationary idle condition (ie car out of gear and/or clutch depressed).
Th ECU then richens the idle to make it smoother. The consequence of a failure of the neutral switch was that the idle got a bit lumpy (and your 4WS system stopped working on a MX6 turbo
As far a 6sp vs 5sp ratios - with the correct diffs the 1st gear and top gears are almost identical. The 6sp is just a closer spaced box. You will need to change your diff to a 3.6:1 if changing to a 6 speed or you will be grossly underdriven with the 4.1:1.
What most of us SP owners (and you too by the sounds) really want is a 3.4 or 3.3:1 diff to stretch out first gear and then bring the rpm down to about 2500rpm on the freeway - right in the middle of turbo torque country
