NA6: Diff housing disassembly
mightyrollaman
Postby mightyrollaman » Wed Apr 25, 2007 5:23 pm
Just trying to pull down my old diff to see exactly where she went wrong and I've hit a bit of a wall.
I'm trying to separate the aluminium and cast iron sections of the housing. I have removed the bolts around the perimeter but the bits that attach to the axles (for want of a better term) seem to be holding it all together. I can't work out how to remove these bits. According to my diagram, it looks like they're held in by circlips, but I can't work out how to access them.
Any advice?
The Rolla is mightier than the sword.
Russellb
RIP Nov 2014
Postby Russellb » Wed Apr 25, 2007 6:41 pm
Get a big lever bar and pry them out
should take a bit of force
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Grumpy
Postby Grumpy » Wed Apr 25, 2007 7:28 pm
russellb is rght. i found a timber wedge the go. Put it between the housing and inside the flanges on the axle shafts and give it a whack. Even 2 wedges from 180 degrees apart works.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
mightyrollaman
Postby mightyrollaman » Wed Apr 25, 2007 7:58 pm
Much appreciated fellas. I'll attack it with force in the morning.
