3rd gear sticks when accelerating and going up hill
Posted: Wed Apr 11, 2007 9:09 pm
by skimad
Hi,
I was going up a bridge the other day and accelerating through the gears i got to 3rd gear and then went to change to 4th but couldn't (easily) it was like it was stuck. After slowing down it was easier to change.
This happened again today coming home. Any ideas?
Thanks in advance
Posted: Thu Apr 12, 2007 11:57 am
by skimad
bump
Nobody knows what could be causing this?
Posted: Thu Apr 12, 2007 3:26 pm
by JBT
Possibilities are:
1. Dodgy hydraulics (slave or master cylinder or not enough fluid)
2. Pressure plate going bad
3. Stuffed selectors
4. Jammed shift mechanism
5. Stuffed transmission (shafts moving around due worn out bearings - it should be making bad noises too)
Posted: Thu Apr 12, 2007 3:47 pm
by skimad
Thanks JBT.
It is making some noises and when I had it inspected the NRMA dude said that it could need replacing soon. Maybe soon is now. Just funny its only when I accelerate hard uphill.
Thanks again
Posted: Thu Apr 12, 2007 6:56 pm
by JBT
The forces within the transmission change relationship during acceleration/deceleration. e.g. a rapid throttle off from a fairly hard acceleration will induce a transmission to jump out of gear if it is badly worn. So other things like you're experiencing can happen too.
Posted: Thu Apr 12, 2007 7:19 pm
by deez
I had very similar problems (2nd gear though) and thanks to JBT's advice and others, had it fixed before. My gearshift is now buttery smoooth baby
Replaced clutch master and slave cylinders.
Taken up the free play in the clutch pedal.
Motul 300 gearbox oil put in.
That was my fix
