3rd gear sticks when accelerating and going up hill
skimad
Postby skimad » Wed Apr 11, 2007 9:09 pm
Hi,
I was going up a bridge the other day and accelerating through the gears i got to 3rd gear and then went to change to 4th but couldn't (easily) it was like it was stuck. After slowing down it was easier to change.
This happened again today coming home. Any ideas?
Thanks in advance
SOLD - Red NA - NB wheels, Lock Stewart, fluffy dice
skimad
Postby skimad » Thu Apr 12, 2007 11:57 am
bump :)
Nobody knows what could be causing this?
JBT
Postby JBT » Thu Apr 12, 2007 3:26 pm
Possibilities are:
1. Dodgy hydraulics (slave or master cylinder or not enough fluid)
2. Pressure plate going bad
3. Stuffed selectors
4. Jammed shift mechanism
5. Stuffed transmission (shafts moving around due worn out bearings - it should be making bad noises too)
skimad
Postby skimad » Thu Apr 12, 2007 3:47 pm
Thanks JBT.
It is making some noises and when I had it inspected the NRMA dude said that it could need replacing soon. Maybe soon is now. Just funny its only when I accelerate hard uphill.
Thanks again
JBT
Postby JBT » Thu Apr 12, 2007 6:56 pm
The forces within the transmission change relationship during acceleration/deceleration. e.g. a rapid throttle off from a fairly hard acceleration will induce a transmission to jump out of gear if it is badly worn. So other things like you're experiencing can happen too. :(
deez
Postby deez » Thu Apr 12, 2007 7:19 pm
I had very similar problems (2nd gear though) and thanks to JBT's advice and others, had it fixed before. My gearshift is now buttery smoooth baby 8)
Replaced clutch master and slave cylinders.
Taken up the free play in the clutch pedal.
Motul 300 gearbox oil put in.
That was my fix :)
89 Eunos Roadster
