deleted
Craig
Postby Craig » Thu Apr 05, 2007 8:48 pm
Castrol Synthetic will do the job perfectly, but put a sacrificial cheap one in first to 'cycle' out the crap into it, and then put in the Synthetic.
Fatty
Postby Fatty » Thu Apr 05, 2007 9:00 pm
good tip craig. i might do this too .
is there a particular type / grade of castrol synthetic to use for different cars, or is it the same regardless?
Craig
Postby Craig » Thu Apr 05, 2007 9:06 pm
Castrol Syntrax SAE 75W-90 - Full synthetic API GL5 works great in my car.
Fatty
Postby Fatty » Thu Apr 05, 2007 9:07 pm
excellent 8)
and in the meantime just use the cheapest crap i can find, for a week or 2 ?
Craig
Postby Craig » Thu Apr 05, 2007 9:11 pm
If you can get it cheap enough just use the Castol Synthetic, not sure on pricing myself.
Run it for 5000 klms to really cycle the grit and muck out. In my NA I ended up flushing it 4 times in total to get rid of the notchy/grinding and at the last attempt it was like a hot knife through butter...Matt can attest to that! :)
Done it twice on the NB8B and will do it again at the 50K service. :)
Fatty
Postby Fatty » Thu Apr 05, 2007 9:14 pm
great tip, i gotta remember to do this!!! thanks.
so you mean 5000k in total, changing oil a few times along the way?
or change oil every 5000k, meaning a total of 20,000k ?
sorry for all the questions, i just wanna get this right.
Craig
Postby Craig » Thu Apr 05, 2007 9:20 pm
I don't think there's an exact science really but I think 5000klms is a good point to pull the oil and do it again, it's what I just happened to do as I'm a fussy bugger and pondered that if the first time improved the shift, what'd happen successive times after that? I just stopped at 4 as it was mint after that. 8)
Bear in mind I'm no mechanic but! :lol:
Fatty
Postby Fatty » Thu Apr 05, 2007 9:22 pm
cheers craig, i'll give it a go. it's really not that bad at the moment anyway, but i reckon it could be better than it is. will try it out and report back in a year or so once i've changed the oil out a few times :mrgreen:
Craig
Postby Craig » Thu Apr 05, 2007 9:23 pm
Change the turret oil too and the bushing at the bottom of the gearstick as well! :mrgreen:
franjae
Postby franjae » Thu Apr 05, 2007 11:22 pm
I had the Redline oil, for the gearbox and diff, rags, coffee, cola, snackes,etc and ready to jump in......
Man, this car is seriously low......can't even see where the drain and fill plugs are!!!
How do you guys raise the car high enough (safely) to crawl underneath? You may not appreciate how difficult it is if you wear glasses as they keep falling off! B*sta*d !!!!
So I've finished the coffee and cola and the snacks but done f-all !!!
I'm a good DIYer, but not good if I can't get to the plugs!!!! :roll:
franjae :)
NC sold, but will return one day.......
Alex
Postby Alex » Fri Apr 06, 2007 12:14 am
franjae wrote:How do you guys raise the car high enough (safely) to crawl underneath? You may not appreciate how difficult it is if you wear glasses as they keep falling off! B*sta*d !!!!
a jack and some proper stands generally does it for most
if the cars too low then
http://www.graysonline.com.au/lot.asp?LOT_ID=1398293
and stands
http://www.graysonline.com.au/lot.asp?LOT_ID=1398284
Never work under the car that's just supported on a jack always have it on proper jack-stands
franjae
Postby franjae » Fri Apr 06, 2007 10:58 am
I wonder if the missus will notice an inspection pit in the garage? Should I start digging?? :P
franjae :)
Craig
Postby Craig » Fri Apr 06, 2007 1:24 pm
franjae wrote:I wonder if the missus will notice an inspection pit in the garage? Should I start digging?? :P
Yes but do your own grave first! :lol:
Craig
Postby Craig » Fri Apr 06, 2007 1:53 pm
Cycling the fluid makes sure all the rubbish is gradually removed with each subsequent oil change. With every change I did on the NA the less gunk/metal shavings there were floating around in the oil and it could do it's job properly without grinding and carrying on. The first oil change was done at 43,000klms and the oil on removal was putrid and gluggy...scary huh for such low klms!
The bush on the bottom of the shifter looks like this
Good reading found here >>> http://www.miata.net/garage/trans/everything.html
Craig
Postby Craig » Fri Apr 06, 2007 1:54 pm
P.S. Replace both the rubber boots. Mania can source them for you as well as the lower bushing if you don't have one.
