Cat convertor for turbo - metal or ceramic core and why?
Posted: Wed Apr 04, 2007 3:52 pm
by Uncle Arthur
From those who've gone turbo - do you use a ceramic or metal core cat convertor, and for which one, why?
Posted: Wed Apr 04, 2007 3:54 pm
by mossy
I use a metalcat cat convertor, it pretty exxy at about $350 but from the searching I did on google it seems to be the best there is.
Posted: Wed Apr 04, 2007 4:12 pm
by The Pupat
I thought the best cat for a turbo was any modified* version.
*modified with a big screwdriver or steel pipe through the guts
Posted: Wed Apr 04, 2007 5:35 pm
by Sheck
i've been running a stocko one (off some import) and am going to be useing a metal cat with my new turbo. i'll let you know how it goes!!
Dave
Posted: Wed Apr 04, 2007 6:06 pm
by 16bit
if you have seen the centres side by side you will see that the metal buscuit flows a lot better then a ceramic one. I would go metal for any modified exhaust application - turbo or na.
Posted: Wed Apr 04, 2007 9:26 pm
by Babalouie
I've got as metal cat on the rotary. If you pick one up and hold it against the light, you can pretty much see thru it, so they must flow well. Also the metal substrate is stronger and can withstand heat from the turbo better, so that
this doesn't happen (which is a non-metal cat that was in my car...who said rotaries are hard on their cats!):
Posted: Fri Apr 06, 2007 7:06 am
by ASE05
metal cat on my puppy.
Mate with an F6 Typhoon swapped the stocko for a 3.5\" metal cat and picked up pretty impresssive numbers (5+ rwkw) on the dyno
