200rwhp SE
blackster
200rwhp SE
Postby blackster » Thu Mar 22, 2007 8:23 pm
Managed to get the SE on the dyno today after completion of the 3rd round of mods. I am very happy with the end result.
Stock 101rwkw
1st Mod
SPM Exhaust & BOV
113.8rwkw
8 PSI
AFR low 10s
2nd Mod
FM Ebay intercooler
120rwkw
8 PSI
AFR low 10s
3rd Mod
AEM air intake, Boost controller @ 10 PSI, BEGi TB inlet & FM 02 clamp
149.4rwkw
10 PSI
AFR 12.1
Previous
04' MX5 SE.
02' MX5 Classic ed.
AJ
Postby AJ » Thu Mar 22, 2007 8:51 pm
nice one blackster, i think ASE05 is getting similar figures from his SE 8)
XMX5 Rogues
StanTheMan
Postby StanTheMan » Thu Mar 22, 2007 8:56 pm
now if you'd said 200 RWkw...... that would be worth bragging about
why can't you stick to metric?!!!
Postby bruce » Fri Mar 23, 2007 5:03 pm
But 200 anythings sound so nice!
ASE05
Postby ASE05 » Fri Mar 23, 2007 6:12 pm
schweeet, GO THE SE :mrgreen:
Do you find you get an extra kick of power @ 4 ~ 5000rpm + rpm still or did the O2 signal thingy fix it?
Chiptorque reckon they can get it outta mine but by the time I get down there again, there won't be no standard ECU in place to cause woe.... 8)
Sing that song, puff all night long.......
blackster
Postby blackster » Mon Mar 26, 2007 3:41 pm
Since the application of the FM 02 clamp the hesitation at 4000 to 5000rpm followed by the 5000rpm surge has reduced. To get rid of it all together, a full "standalone" is required according to FM. I guess for $100 you cant expect too much....
Previous
04' MX5 SE.
02' MX5 Classic ed.
Postby bruce » Tue Mar 27, 2007 2:23 pm
What is an O2 clamp? Is it just a bit of electronic trickery you wire in?
Boags
Postby Boags » Tue Mar 27, 2007 2:38 pm
bruce wrote:What is an O2 clamp? Is it just a bit of electronic trickery you wire in?
Yes.
It is a pressure switch which senses the boost pressure in the intake manifold. Once the pressure becomes positive (boost instead of vac) it sends a signal to the stock ECU saying that the air/fuel ratio is a little lean. The stock ECU then adds more fuel to compensate for this lean condition and smooths out the transition onto boost. What happens without the O2 clamp is; the stock ecu notices the piggyback is making the mixture richer for boost. As the ECU only likes an a/f ratio of 14.7 when in closed loop, it pulls fuel (leaning out the mixture). The 2 are fighting each other basically, and the car bucks as it goes from rich to lean.
There are a few much cheaper versions of the same thing, I've heard the FM unit comes on a little soon making the car drink fuel and buck during highway cruising. Perhaps they have fixed this with newer models.
I have one with my setup (yet to be wired in).
Boags
Postby bruce » Sat Mar 31, 2007 11:52 am
Thanks for that explanation. These them car-doover-lackeys are getting more comp-lee-kate-ed.
Boags
Postby Boags » Sat Mar 31, 2007 12:15 pm
I wrote:I have one with my setup (yet to be wired in).
Just to clear that up, I have a knock off made by a forum member in the US, not the FM unit.
Sean
Postby Sean » Sat Mar 31, 2007 1:34 pm
lil_mike wrote:nice figures.
just a quick question. what gear was that in first? and secondly about where in there would you be at 5200rpm (i hate it when they put it in km/h). just curious about something.
Methinks you are trying to jusdge the accuracy of the readings by looking where torque and power cross in relation to the magic 5200 8)
Not always an accurate reflection of how accurate teh dyno is.
blackster
Postby blackster » Sat Mar 31, 2007 6:58 pm
All my power runs have been in 4th gear, it would be impossible for the car to be spinning on the dyno @ 150km/hr and still be in first. At 149.4rwkw the car was at 6500rpm (rev limiter), the car felt like it had more, you can see at the tip of 149.4kw there is a drastic loss of power as opposed to the other runs (with less mods) where it curves off.
Remove the rev limiter may you ask? Im not game as the consensus is that there is not to much gain after that (duty cycle) without injectors and some sought of piggyback.
Previous
04' MX5 SE.
02' MX5 Classic ed.
