Not that I own a 5, but I have always wondered...
Regards the CAI with the hole in the firewall - if you reverse the mod, does the washer bottle cover up and hide the hole perfectly?
CAI question
- bruce
- Vehicle: NA8 - Turbo
- StanTheMan
It depends on the size of the hole that you cut. If you are putting in a loch Stewart CAI you use a 75mm hole. The washer water bottle doesn't quite cover that hole. If using one of the other CAIs that requires a smaller hole then the washer water bottle may cover it.
J
J
- bruce
