Moving number plate
Moving number plate
Question:
I have a slim line front number plate mounted on a bracket that has the plate upwards on nose cone. Can you mount plate in \"gap\" on front without upsetting the cooling?? I have seen some photos of this done, but wonder about air flow to radiator.
Robbiew.
Robbiew.
Moving number plate
Thanks....unfortunately LOVE spirited driving...any other kind in a 5?? Seriously, does get the odd workout so maybe leave plate where it is....
Thanks for the prompt reply
robbiew
robbiew
- Alex
- Mr_Q
- Vehicle: NA8 - Turbo
- broady
SM wrote:you could also try the "jap" mounting method where a braket is placed on the passenger side front toe/shipping loop, so number plate is mounted off-centre and not in the way of the front grill in any way
Is there a write-up on such mounting methods?
- jules
- Guitar Hero
Try this http://www.onthenet.com.au/~malibu91/julesplate.htm
I'm happy with the result. It's legal and the car won't overheat.
Jules
Jules
moving number plate
Thanks to all who replied....I will certainly have a go at the mods suggested....and post results if I do a reasonable jobbie !!!
robbiew
robbiew
- zoomzoom
- Vehicle: NA6 - Turbo
I made two small brackets for mine which bolt onto the very underneath of the nose cone where you would bolt on a front lip spoiler. There are two bolts there almost the right distance apart. I tried mounting it offset to one side but didn't like the look so I put t there, is out of the way of most of the air flow and looks a little like the shark mouth is eating it
Sry I dont have any pics I dont have the car right now, its at the shop getting the sills done.
Tim
Tim
- Sean
Take it off...
Take it all off...
Go to the local RTA office and tell them someone stole it, and ak for it to be remade. (cost is approx $30).
They will give you a receipt stating the plate is being remade. Keep the receipt in the glove box - bit conveniently spill a little sun block over the date so it fades or runs into obscurity.
HEY PRESTO you have a get out of gaol free card
$30 and some sunblock is cheap compared to actually doing some physical work and buying materials
Take it all off...
